Best 2x12 plate setup?
Old Oct 22, 2001 | 02:59 PM
MrJ's Avatar
MrJ
Plates suck.
lol.... but I got one free. A friend of mine happened to have a plate, for a thirdgen, with 2 MTX 12s on it. He gave it to me for free. It's a little rough, it needs cleaning, and I don't know if the subs on it are any good. They look rather old. They are 2 MTX PY-12s, rated at 100w each. The plate also contains 2 pods on each side, each housing a midrange and a tweeter. I had planned to go with a tube setup eventually, but this thing is free, I'd be a fool not to use it. Right now all I have is a Pioneer DEH-P7000 deck powering 2 Polk 4x6s and 2 Pioneer 6x9 3 ways.
1) Are these subs any good? That is, assuming they work.
2) What should I use for an amp? I don't think I can use a mono amp, because I wouldn't be able to get power to the midrange and tweeter with a single channel amp, would I?
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
ported TPI setup
Built on Wednesday
Old Oct 22, 2001 | 03:27 PM
Polecat's Avatar
You'll need woofers that can play in a "freeair" design. We make a new Comp VR woofer (www.kicker.com) that can be used in sealed,vented or a freeair setup. Get a good amp that puts out alot of power, and run it solely to the subs. Use the stock locations of the car for the mids and highs.
Old Oct 22, 2001 | 03:35 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Plates suck.
With free air speakers, plates suck .00002% less.
My experiences are that if you insist on running a plate, don't waste money on a good amp. My old $200 jensen amp could push my subs beyond their limits on my plate because after a certain point, the excursion gets out of control. A free-air sub will be better because it's excursion is damped, but your output will not increase with more power at any sort of appreciable rate because you're still dealing with a huge amount of cancellation from the lack of a box, and the more power you feed it, the worse it gets. For the most part, you hit a brick wall in terms of output capibility, and you can usually reach that plateau with a low power amp.
Free-air subs can work good in a trunk situation where you're able to effectively isolate the rear soundwave. The damping of the sub then becomes the only major issue, which is why a free-air sub is designed accordingly. But in a thirdgen, the front and rear soundwaves are still sharing the same cabin, and the rear soundwave is only being partially isolated. This just turns into a big flaming pile of sh*t.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 22, 2001 | 03:41 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
You could always build a box, using the plate as the top.
Hotrodboba400
Dec 10, 2019 07:07 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Kenwood
Sep 11, 2015 12:50 PM
drb930
Sep 9, 2015 10:53 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
