Anyone else get the annoying plastic buzz in the dash????
Old Oct 24, 2001 | 10:15 PM
CamaroX84's Avatar
I've noticed that whenever there is any kind of loud volume up front, the dash vibrates. When I squeeze the dash pad down, it goes away. I've tried tightening down the screws, doesn't help. You guys think foam tape would help? I know there are a million combinations that can make a buzz, but has anyone had a similar one? Thanks.
Old Oct 25, 2001 | 09:13 AM
adamyeo's Avatar
I had a similar problem with my Camaro's dashpad buzzing and rattling and bouncing so I took the dashpad off, stuffed a couple old rags and some old socks under and put the dashpad, problem solved and what people can't see won't hurt them. If you want to be fance you could probably use some kind of sound deadening to do the same but I didn't...mine works good.
Old Oct 25, 2001 | 09:25 AM
Smeg's Avatar
Car: 1990 Black TransAm GTA hardtop
Transmission: THM700R4
Axle/Gears: 3.23 w/Alu prop
They may not see it, but if they smell them old socks when the heaters on, your in trouble boy...
Smeg
89 GTA 5.7 TPI
Old Oct 25, 2001 | 02:43 PM
OldOneEye's Avatar
Car: 1997 Nissan 200SX SE-R
Engine: 2.0 Liter SR20DE
Transmission: 5 Speed
I think the question should be if someone doesn't have that rattle. Mine had it. Few ways of fixing it. Adding mass (making it harder for stuff to move it) like sounddeadener on parts and keeping parts from squeeking (it might be a plastic on plastic noise... so use something like velcro (works pretty good on the loop side) or a foam weatherstripping tape, or even just pieces of carpet.
Juan
GTAman
Jul 3, 2024 07:29 PM
MantyZ28
Nov 8, 2015 06:54 PM
gta892000
Sep 16, 2015 12:37 AM
Saxondale
Sep 15, 2015 06:42 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
