My System
Old Nov 8, 2001 | 04:34 PM
nagga's Avatar
My System
my car is an 84 z/28, im gonna build the sub enclosure out of fiberglass, im gonna run 2 JL 12s and an MTX amp, alpine CDM-7871 head unit alpine 4 way 6x9s, pioneers in the dash, i would make kicks but theres not much room for them, also i was wonderin if anyone could tell me how much air space is there in the t top storage area, i think theres enuff for 2 12s, they call for about 1.25 cubic feet, so ill need 2.5 cubic feet, i will take some pics as i go along with the install, also my new motor 320hp 350 that im building
Old Nov 8, 2001 | 05:29 PM
DJSexay's Avatar
there is always room for kicks!
Seriously, you only use about 3" of foot room with my kicks.
mike
custom 3rd gen kickpanels at
http://www.djsexay.com
Old Nov 8, 2001 | 07:59 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
There is enough room for two 15s in the hatch area if you want to put 15s instead of 12s. I have two 15 inch kickers in my hatch and they fit perfect in a camaro/firebird box I bought from a car audio store.(bigger is always better) As for the kicks, my car came equipped with a bose stereo system and had the factory kicks already there, so if you can locate them for a bose equipped car, they will work great and look factory. Hope this helps you out.
Old Nov 9, 2001 | 04:05 AM
TrueBlue91RS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by jermdm:
(bigger is always better)</font>
Dude, I don't know. Quality is always better
I've rarely heard a 15" sub that I liked better than the equivalent 12", but it totally depends on what kind of sound you're after. People don't just buy 10's or 12's 'cause they prefer the smaller, "inferior" setup. It's whatever sounds best to you after giving them all a listen. Not knocking 15's, I just don't think that they're the answer to everybody's system needs.
Anyway, there are some fairly creative box designs out there that can provide considerable volume for a sealed enclosure, so it shouldn't be a problem squeezing in the JL's. But I don't know any exact airspace numbers for the well.
Old Nov 9, 2001 | 06:14 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I gotta ask.......
Are there alot of Camaros let alone ones with T-tops up there in Alaska???
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Richmond 3:42 gears, Torsen HD Posi
Sights & Sounds:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers. Z28 grille w/aftermarket lights, MacEwen whiteface gauges
NEXT UP: TBI & Suspension mods
Old Nov 9, 2001 | 11:42 PM
camaroman305's Avatar
Well, first off JL is NOT the way to go. I worked at an audio shop for a while. Sampled most speakers and bench tested them. JL has never met my requirements. I suggest some kicker solo baric square 12s, or if those are too expensive, some rockford fosgates will outperform the JLs by a longshot. And you gotta have the kicks man
Old Nov 10, 2001 | 03:13 AM
nagga's Avatar
lol theres tons of camaros, most with T Tops, also **** loads of corvettes and old muscle cars, i restore them with my uncle
Old Nov 11, 2001 | 06:03 PM
Belker's Avatar
YES - you can build a custom box to fit in the well area that has an internal volume of 2.5 cu.ft. (or more, especially if you go with a fiberglass box).
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
Night rider327
Oct 9, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
