what reciever was original in 84
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
mines gone and i want to put one in and the original reciever harness plugs are unmodified and i want to keep thjem that way, but they are uncommon style IE i cant use plain spade connectors to tie into them to put any other deck into the dash, so...
how big and what kind of reciever would a car with these options get? pics would be good, i assume delco brand was always used from factory no matter the RPO codes ? were they shaft style or no ? 1984* could i put one from an 85 suburban in the car ? plugs look same to me, but size of unit, hmm... lemme know anytihng i need to know at all.,
UA1 : BATTERY, HEAVY DUTY
UE8 : CLOCK, ELECTRIC, DIGITAL
UP8 : STEREO RADIO INSTALLMENT PROVISIONS
UU2 : RADIO, AM/FM STEREO, CASS, DOLBY, ETR
U75 : ANTENNA, POWER, RADIO
U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VAN : ASSEMBLY PLANT, VAN NUYS, CA
thanks
for anything
thanks
for anything
Car: 1987 Chevrolet Camaro Z28 IROC-Z
Transmission: TeamTripp Performance
68,
There were several audio options available in ’84,including:
AM Radio
AM/FM Radio
ETR (Eletronically Tuned Receiver) AM/FM stereo radio with digital clock
ETR AM/FM stereo radio with cassette tape and digital clock
ETR AM/FM stereo radio with seek and scan, cassette tape, digital clock, and graphic equalizer
I’m not sure about the AM and AM/FM radios, but the ETR’s were not shaft style, they were 1.5 din with the tuning and volume ***** on the left like most thirdgens. Check eBay for pictures, I don’t know of anybody other than Delco who made radios for thirdgen Camaros.
AM Radio
AM/FM Radio
You can buy a harness that will plug in to your factory one and allow you to install a new radio without cutting the factory wiring out. I got mine at Best Buy for around $15.
Almost forgot, the one you have from the '85 Suburban should fit, just try it out.
Engine: 4.3L Z TBI
best buy, hmmm ill have to find one of those in big city somewhere and see what I can find. only two cut wires i know of in the car, the dome lamp orange feed at the driver kick panel and the underhood lamp feed wire, i odnt wanna cut any i dont have to, hehe
thanks guys !
thanks guys !
Engine: 4.3L Z TBI
hope it fits, im afraid to try it, looks bigger than the hole in the dash heh, then i probably wouldnt need adaptor, heh.
thanks
thanks
84 TA NV
Sep 6, 2015 08:02 PM
