stock system
Old Mar 22, 2002 | 01:01 PM
velocity92RS's Avatar
stock system
I have the bose gold system that came stock in my 92 RS, with an aftermarket deck I installed. As I understand it, and I may be way off, the stock speakers run at 1/2 ohm and each have an amp hookded up to them. If this is the case, what are my replacement options?
Old Mar 22, 2002 | 02:49 PM
deadtrend1's Avatar
usually you'll be needing to replace the speakers and run new wires from the aftermarket headunit (or amp) to them.
Old Mar 23, 2002 | 01:28 AM
caleb's Avatar
Car: 89' Iroc
1 amp per speaker? or one amp for all for speakers? if it were one for all, then they are proably all 4 ohm speakers, wired in parallel, thus cutting the load to half an ohm, but it would have to be a DANG good amp to run @ 1/2 an ohm!
Old Mar 23, 2002 | 02:15 AM
I was told that they each had an amp and that the speakers ran at 1/2 an ohm. I know that most aftermarket speakers run at 4 or 8 ohms, so my options are limited if this is the case. I tell you what, this system sounds clearer and better, the louder you turn up the music!
Old Mar 26, 2002 | 12:31 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Peripheral BOSE Interface
Buy a Peripheral electronics Interface for the system and save yourself the time & hassle of replacing all the speakers and re-wiring the whole car !!
The interface will allow a Stock BOSE head unit to be replaced by ANY non-BOSE reciever and still run the BOSE speakers and amps without any problems.
These things cost about $60 - $70 and are really easy to install (if you have ever installed a radio in a car before - you will have no problem slicing the interface into your system.) The Interface has ajustable "gains" for each of the 4 channels to allow you to tweak the sound volume on ech speaker to be just the way you like it.
The Interface also has a GM plug on the back of it so you don't have to cut your factory Harness. (in case you havn't already done that ! )
You can see the interface by clicking on this link (or cut/paste this link into your browser ! )
* Click to see the BOSE Interface *
Old Mar 26, 2002 | 02:08 AM
sixpack's Avatar
I have the interface already. I am wondering how I can put in new speakers, not the deck, the deck is a new Pioneer.
MustangBeater20
Oct 29, 2022 09:20 PM
Grant2k
Jul 10, 2018 04:01 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
sreZ28
Aug 14, 2015 07:48 PM
