amp help
Old Mar 22, 2002 | 11:49 PM
caleb's Avatar
Car: 89' Iroc
amp help
i have two infinity reference series 10's they are rated @ 250 watts RMS, i am using a us acoustics usx2100 it is rated at 300 watts RMS when dridged @ 4 ohms, if i wire my 2 subs in parallel, will it hurt the amo to run it bridged @ 2 ohms, it is t2 ohm stable when not bridged.
Old Mar 23, 2002 | 12:12 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
its not really good, because its not rated for that kinda load. less expensive amps cannot and should not be run at lower ohms than stated, because you can hurt it. since you were thinking of running it 2 ohms bridged, each channel technically sees 1 ohm, stressing the amp. higher quality amps are more likely to handle this kinda of stress. i've got an mtx amp running at 2 ohms bridged and its not even getting warm. but just be careful. manufacturers will not honor a warrenty if an amp is used incorrectly (not at suggested ratings/levels/etc)
Old Mar 23, 2002 | 01:25 AM
caleb's Avatar
Car: 89' Iroc
ok, thanks for the suggestion, i think im going to run it 100 watt by 2@ 4 ohms, just to be safe :hail:
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
