custom sub box
Old Mar 26, 2002 | 03:17 PM
92RSMuscle's Avatar
custom sub box
hi
i have the plans for the custom sub box, i know all about sealing it and ****...but i have ta know if anyone knows if you can put 3 subs in there....also, does anyone know if home depot will make all the cuts for me?
lastly, does anyone know how to take apart the front dash to expose speaker wires?
thanks
mike
Old Mar 26, 2002 | 03:26 PM
caleb's Avatar
Car: 89' Iroc
home depot will make the cuts, but they will probly want to charge you a certain amount for each cut. As for 3 subs, i have seen boxes in third gens, that have 3 12's, and others that have 3 10's
Old Mar 26, 2002 | 07:02 PM
afast87's Avatar
well, that would depend on speaker size, ported or sealed, and the factory recomended volume. i am pretty sure you can squeeze 2 cubic feet or so out of the trunk space, but you will have to be creative.
Scott
Old Mar 26, 2002 | 07:20 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Re: custom sub box
thanks
mike
There are 6 or 7 screws under the dash pad in front (close to you). There are also 4 or 5 on the front window defrost vent.
Just make sure you use a magnetic socket or nut driver, or even put a magnet next to the screws by the defroster vent. Otherwise you WILL drop at least one screw in the vent. Lord knows we all have.
AJ
Old Mar 26, 2002 | 08:13 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You better have some DAMNED good box plans if you think you're going to have Home Depot cut it all and it's going to all go together when you get it home. I've built dozens of these boxes, and there's still a pile of pieces that I need to re-measure on a per-box basis because all boxes come out just a little different.
Old Mar 27, 2002 | 01:26 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
When you make the box seal it well. Nothing worse than going thru the work and having it sound like crap because the box is not sealed properly.
A buddy of mine almost trashed his 12in Pioneer that is in my car now because of a bad box. I talked him into letting me take it and I built a new box to custom fit in the back. I sealed the seams of the box with caulk after I built it and put in some poly fill (afraid I might have not made the box quite large enough). It hits extremely well.
HP52TA
Feb 3, 2018 10:51 PM
bubbaz28
Sep 18, 2015 02:09 PM
Deemax
Sep 12, 2015 06:53 PM
Ranbo108
Sep 9, 2015 12:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
