Question about setting float level on Holley
Old May 25, 2001 | 02:59 PM
Biochem's Avatar
Car: 2002 SOM z28
Dual bowls, 750vac, the pressure is about 6psi mybe 7psi tops.
If I remove the sight plug from the side of the bowl with the car off, only a little gas drips out when I rock the car.
If I turn on the car, then gas pours out the hole like it ate some bad clams!
Is this about right? I am running a tiny bit on the rich side and want to tone it down a notch. Thanks.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old May 25, 2001 | 03:16 PM
Jester's Avatar
Well you should really set the float level with the car..or at least the pump if it's electric, running. You get it the most accurate that way.
If it just overflows when the pump is running, then you may have a screwed up needle and seat thats not sealing. That'll definatly make ya run rich.
I recommend starting with the float level very low, then slowly raising it to where you want it. I've found the best results with it so it just barely dribles out when the car is rocked.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old May 25, 2001 | 07:19 PM
82camaro's Avatar
Car: 82 camaro SC
It needs to be running and like he said, just a little comes out if you shake the car.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old May 25, 2001 | 07:46 PM
Biochem's Avatar
Car: 2002 SOM z28
If the needle is off the seat, how do I get it back on? I have taken the metering plate out a few times to change jets... will that mess it up? What do I need to look for?
Old May 26, 2001 | 01:18 AM
Jester's Avatar
The needle and seat is one unit, and is replaced as such, takes about 2 min. They're about $10 seperatly..or $20 for a rebuild kit that comes with 2 plus all the other crap.
You know they are bad when lowering the float has no effect, gas still pours out of the hole. They go bad every so often..a piece of gunk will scratch up the seat or jam up the needle. I run a fuel filter right before the carb, it helps alot, but every once in a long while one will go anyway.
JSP Motorsports
ICON Motorsports
Frozer!!!
Jan 19, 2024 04:55 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
355tpipickup
Aug 19, 2015 10:02 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
