Rochester to Holley linkage.
Old May 23, 2001 | 06:40 AM
Trigger84's Avatar
Hey yall, Ive just got my Holley #1850, and I was wondering if there are any changes in the throttle linkage set up. Will I need a conversion kit?
---Grady---
1984 Berlinetta.
LG4 305, 150 hp.
Rochester Quadrajet(Comp. Controlled)
TH-700R4.
Flowmaster 80 series/ 3" cat-back pipe.
Accel Superstock Coil.
7.5 10-bolt rear/ 3.08's.
Edelbrock signature series air cleaner -w- K&N Filtercharger.
Pioneer head unit, Pioneer front 4X6's, Cerwin Vega rear 6x9's.
Daily Driver.
Personal Quote: "The Rice-Boys all tremble with fear when the old American V8 draws near."
Old May 23, 2001 | 06:44 PM
Cosmik Debris's Avatar
I would advise you to get the Holley bracket part no 20-95. This will allow you to mount the throttle cable and the Transmission TV cable in the correct place. You can use the old manifold mounted bracket from your Qjet days but you have to reposition it to make it optimal.
P.S. I see you are replacing a CC Qjet, have you got a vacuum advance distributer and some means to lock your torque convertor?
[This message has been edited by Cosmik Debris (edited May 23, 2001).]
Old May 23, 2001 | 09:15 PM
Trigger84's Avatar
Where will it need to be relocated to? I'm gonna be using an Edelbrock Performer intake, if that makes any difference.
---Grady---
1984 Berlinetta.
LG4 305, 150 hp.
TH-700R4.
Daily Driver.
Old May 23, 2001 | 11:22 PM
The old Qjet bracket mounts under one of the manifold bolts. When I put my Performer RPM manifold and Holley on the bracket in it's standard posion wasn't correctly lined up with the throttle arm of the carb. This doesn't matter much for the throttle but can cause transmission problems with the TV cable. Buy the bracket, it is $15 or so of your money. This bracket goes under one of the carb studs and puts everything in the correct place.
Old May 26, 2001 | 01:38 PM
Trigger84's Avatar
I'll look into getting one of those brackets. And as far as the dist. goes, I've gotten a vacuum advance one. But, I've heard that removing the pollution control system and CC doesnt affect the torque convertor lockup.
---Grady---
1984 Berlinetta.
LG4 305, 150 hp.
TH-700R4.
Daily Driver.
Old May 27, 2001 | 05:35 PM
I'm not 100% sure on the lockup thing. I think it will still work but some people have told me it doesn't. Maybe someone else will comment.
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
