How?Where?What size?
Old May 24, 2001 | 02:56 PM
Metallica383's Avatar
I have been reading over old quadrajet forums and have been reinspired by there gas saving ability along with what seems to be endless things that can be accomplished with them. I have to carbs one a quadrajet and the other is a holley quadrajet replacement it is a squarebore carb also. I am trying to decide what to use the quadrajet I have on right now needs to be rebuilt I was wondering if the holley replacement carb could get as good of MPG as the quadrajet? I also would like to know what would be the smallest primary jet size to go with on either carb to get maximum power and MPG also? It is a 383 with a comp cam with .454 lift?
Thanks for all the help Guys!
Old May 28, 2001 | 03:59 PM
82camaro's Avatar
Car: 82 camaro SC
Jetting for maximum power isn't the same as maximum mpg. Every engine is different so I would hate to guess a jet size. Running an engine lean can melt it down(overheat). Bigger engines use more fuel, so your 383 isn't going to be a mileage queen. Both the holley and q-jet, set-up equally will give you about the same mileage and performance.
Q-jets are spreadbore, so I assume you are talking about a spreadbore holley.
The carb is just part of mileage. Ignition timing, good ignition parts, proper jets, gears, right foot pressure, aerodynamics, ...
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Pac J
May 17, 2020 10:44 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
