Need Holley FP help
Old Jun 9, 2001 | 06:17 PM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
Need Holley FP help
I've replaced my stock fuel pump with a Holley 12-327, 110gph, 6-8psi street pump. It does fine 1 & 2 gears to 5000rpm and when I shift it into 3rd gear and hit 4600rpm it falls flat on its face. I can let all the way off the throttle and then nail it again and it does good to 4600rpm again. What's going on?
I plugged the fuel return line because the new pump doesn't use it. I bought a new in carb fuel filter but I think I'm going to take it out and just use an inline. I checked the in-carb fuel filter before I put it in and it had a little check valve in it and it seemed like I had to blow hard to get air through it.
Let me hear some ideas/solutions. Thanks in advance. See sig for mods.
Edit: I forgot to tell you I am using the stock quadrajet with AU secondary metering rods. Thanks,
Craig
84 Z28 305HO, 5spd, 220,000 miles, Edelbrock intake, Hedman headers, low restriction exh(w/cat), K&N air filter. Best 1/4 so far 14.649 at 94.77mph
Recent additions: Del-A-lum front control arm bushings, Moog ball-joints, Energy suspension front sway bar end links, Moog rear sway bar end links, Eibach pro-kit springs, tokico shocks/struts. Need relocation brackets and control arms.
[This message has been edited by Craig84Z (edited June 09, 2001).]
Old Jun 9, 2001 | 06:40 PM
Jester's Avatar
FWIW I doubt the problem is the pump. That pump should be able to support your setup well past 4600..
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
