Carb missing
Old Jun 6, 2001 | 08:51 PM
AustinT's Avatar
Carb missing
I have a holley 750 with vacumm secondaries on a zz430 motor. The primary's are 73 jets and the secondaries 71's. It has a hiccup when you drop your foot. Then it will miss when your pulling hard. What should I do first?
Old Jun 9, 2001 | 11:14 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
1st, give us the part number of your carb. There is more than one type of 750 vacuum secondary Holley out there. Is this carb new or used?
Next, "typically" the secondary jets are larger than the primaries (but not necessarily). It sounds like you have two problems: 1) The secondary mixture is too lean, and 2) the secondaries are opening before the engine can use the extra flow. Both are tuning issues. I'd suggest richening the secondary jets until the missing under heavy load goes away, then tune out the bog with progressively heavier secondary springs.
This assumes that your ignition is in good shape and you have the timing set correctly. If you're not sure about those things, get the ignition up to snuff before trying to tune the carb.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Old Jun 10, 2001 | 01:43 PM
AustinT's Avatar
Thanks five7kid
The Holley is a 0-80508s with a secondary metering block. I bought it new with the zz430 it only has about 500 miles of use. The Hei also came with the motor and was recurved for the engine by salle-chevrolet. Im pretty sure the the HEi is Ok. Salle chevrolet also put the lightest spring in the Carb the the secondaries would come open sooner. Thanks for the info Ill see what happens with the richer jets and stiffer spring
Old Jun 10, 2001 | 07:45 PM
AustinT's Avatar
I told you backwards 71 in primary 73 in the secondary. Could I still be to lean on the secondary side?
Old Jun 20, 2001 | 12:07 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
check your float levels also.
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression Dart Pro 1 Aluminum heads 215cc,234dur.488lift exh&int,Victor Jr. intake, 770 Holley Avenger vac.sec 400 crank,flat top pistons,tranny shift kit,2500 stall converter. 3.42 ,Hooker Headers,2.5inchpipes with 40 s. Flowmasters,MSD coil,MSD module.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
makaveli09
Sep 15, 2015 10:43 AM
rjcme
Sep 5, 2015 01:23 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
