how do i , or do i need to. prime the fuel pump
Old Jun 21, 2001 | 10:31 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
after its been drained of gas, because i installed new fuel lines. or should cranking the engine for a few minutes just suck gas into the pump???????????
Old Jun 22, 2001 | 04:16 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Just crank it until it fires.
Old Jun 25, 2001 | 09:51 AM
FastBroker's Avatar
I usually make sure the primary bowl has fuel in it. That'll get you running long enough to get fuel to the carb in empty lines... And assures quick startup...
[This message has been edited by FastBroker (edited June 25, 2001).]
Old Jun 25, 2001 | 06:15 PM
82camaro's Avatar
Car: 82 camaro SC
Crank it until it fires up, it won't take very long at all.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
92camaroJoe
Aug 13, 2015 06:07 AM
