big trouble
Old Jun 26, 2001 | 08:38 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
big trouble
my car is an 84 Z with a 5.0 H.O. and it has a 4bbl quadrajunk on it and it dies, backfires every once and awhile and occasionally deisels when i go too shut it off. the previous owner put a coolant temp sensor, a tps .and some other sensors on it and it still does it. It also burns really rich and smokes when first started. any help is greatly appriciated.
Old Jun 26, 2001 | 09:50 PM
zee28's Avatar
Car: 86 iroc
These things were not meant to go 100,000-200,000 miles without service.They can run well if rebuilt and adjusted right.There is more to it then just throwing in a tps,and to do that without replacing the m/c solonoid shows the rebuild wasnt done right.Try again with the rebuild by someone who knows these carbs,The carb shop,JET.or try a remanafactured carb,make sure it has a warranty.Are you getting any codes(check engine)?and is the ignition ok?
~mike~86 IROC-Z
mrbird
Oct 20, 2015 03:43 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
Lmancha96
Sep 25, 2015 08:11 PM
