Edelbrock Performer and Code 23 HELP!!!
Hey,
I have an 86 305 camaro and i put on an edelbrock performer RPM intake and a holley 600... I am getting code 23 now.... the Manifold Air Temp (MAT) sensor, is there anyway to fix this??? The car seems like its running great, but i hope its not in that closed loop stuff????
Transmission: 4L80E/4L80E
Read the descriptions for trouble code 23 again. MAT is for injected cars, you're probably getting it for "Throttle position sensor error". How that would relate to a manifold replacement, I don't know, however.
What do you mean by "i hope its not in that closed loop stuff"? Closed loop is good.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
Whoa, back up the horses - I missed the part about the 600 Holley. No wonder you're getting a code 23 - you just eliminated the TPS!
Unless you also replaced the distributor with a vacuum/mechanical advance type, it's not running as great as it could. If you did, you'll have a permanent code 23, so take the bulb out of the SES light.
Do you have an auto transmission? If so, your TCC is no longer locking up.
Hotrodboba400
Dec 10, 2019 07:07 PM
BumpaD82
Feb 26, 2016 02:57 PM
toronto formula
Sep 10, 2015 07:31 AM
MikkoV
Sep 9, 2015 04:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
