timing setting
Old Jun 27, 2001 | 03:40 PM
ian's Avatar
ian
Car: 83 berlinetta
Transmission: th 700
timing setting
I have a Berlinetta 305 with feed back Q jet & I want to check the static timing I have read where you pull the 4 wire connector & set it to 6 degrees but I have just read an earlyer posting which says that it should be set to 0 could someone pleas put me straight
Old Jun 27, 2001 | 04:11 PM
PonchoTA's Avatar
Factory spec says 0*, but if you are looking for better low end performance and not so much top speed performance, then advance the timing to ~6* and you will really feel the difference! I've heard some people say that you can even go to 8* but only if you use premium petrol.
Hope this helps!
Old Jun 28, 2001 | 03:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Zero is factory for LG4, 6 degrees for L69.
When I set my LG4 at 6, I have to use mid-grade gasoline to prevent pinging - it runs better, but for daily driving, I set it at 3 degrees and burn regular.
Try different settings (starting at 6 is okay), and see what seems to run the best. That's your timing setting.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
