Distributor is wasted - getting rid of computer
Old Jun 28, 2001 | 10:28 AM
Jax86SC's Avatar
Well, the distributor in my 86SC is wasted and I'm going to get rid of the computer controlled stuff once and for all. What parts will I need for this swap? Also, any recommendation on parts would be appreciated. In the ~$500 range... Thanks in advance.
Old Jun 28, 2001 | 07:32 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
you will need a way too lock the converter up if its an auto, they make kits to do it
I own a bad @$$ 84 Z-28
kills:
85-90 formula bird 2 times
some moron in a gran prix
2 different 5.0 stangs
and many other less impressive cars
losses;
not really a loss it was a not so stock mid 80s stang that turned down a side street
Old Jun 28, 2001 | 08:08 PM
SUPER-SPORT-CHEVY's Avatar
Yea the convertor lockup is a prob but you should be able to manage everthing well under 500$
you need a non cc qjet, non cc distributor and your set. To get rid of the check engine light find the grey with black stripe wire on the computer and ground it. Easy stuff but it might just be better to get a replacement CC distributor and leave the computer intact.
a good accle distrubutor can cost 130-200 bucks and the carb qjets are 150$remand but you might as well get a holley 600cfm or edelcrap 600cfm 219.99 wieand action+ or edelcrap performer 120$
SSC
[This message has been edited by SUPER-SPORT-CHEVY (edited June 28, 2001).]
Old Jun 28, 2001 | 08:13 PM
86_327_camaro's Avatar
as far as distributor... you need a vacuum advance distributor. i got one used for $30 at a junkyard but spent @ $100 to replace everything. jegs has a complete one for @$130. if its a carbureted motor (coming out and going in) i think that the only other part you have to have would be the lock up torque convertor switch.
Old Jun 29, 2001 | 02:10 AM
87RS402's Avatar
I done this twice now, what you need to do is find a vacuum advance distributor and normal carb of your preference. A standard HEI distributor will work fine. If it's a manual trans, take apart the wiring harness that comes out of the passenger side fender at the firewall. Find the blue and green wires. Seperate those from the others. Cut everything else and discard. Now the two wire you kept go to the back-up light switch inside the tranny. Your going to need to re-wire that set to work with out the computer (which means your going to cut these too), I'd tell you how but I've been too lazy to do it on mine so I haven't figured that out. If it's an auto your going to need to find the back-up light wires, I'd bet they are the same color and in the same place, but I'm not sure. You will also need a lockup kit for the auto trans and a stand alone fan circut. I bought my circut/relay/sensor kit from schucks for $35 and had it installed in under 30 min. You can run an aftermarket 2 guage kit for the water temp and oil pressure or rewire your stock cluster to work your choice. The previous owner of my 86 had already put in aftermarket guages so I left the stock ones alone.
If your wondering, all of the non computer wires, except for the backup lights, go down the left side. That means the tach, volt guage, fuel guage, starting system, charging system, and eveything else will still work.
If you have any more questions feel free to ask.
codeysabatini
Nov 10, 2015 04:07 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
camarohelp
Sep 22, 2015 03:19 PM
codeysabatini
Sep 20, 2015 11:36 AM
Jlanz55
Sep 6, 2015 03:05 PM
