Help: Complete Bog down!!!!!!!!!!!!!!!!!
Old Jun 15, 2001 | 02:39 PM
dirtyeskimo's Avatar
Hey I have a quadra jet carbed 305. it is a 1986, and right now I am having a huge friggin problem. it is stock for the most part right now. But whenever I start it up and then I start to go, if I hit the gas even remotely hard at all it just bog downs like NO gas is getting to the engine and about dies. so my quarter mile would be about a 25 sec. since I can't accelerate faster then my friends festiva! lol, someone please give me some ideas on what might be the cause of the problem. No tuning or changes have occured since before it started doing this. Thank you
Old Jun 15, 2001 | 06:20 PM
PonchoTA's Avatar
I would suggest changing your fuel filter first. That'll take away most of your problem I think. After that, you might look at how well your fuel pump is pumping. Sounds like you have just enough fuel in the bowl to keep it running, but not enough to support any rpms or vacuum demand.
Hope this helps!
Old Jun 20, 2001 | 12:03 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
yep sounds like fuel restriction is the problem.
Big 454 72 Chevy Nova
383 86 Camaro Z28
10.5:1compression Dart Pro 1 Aluminum heads 215cc,234dur.488lift exh&int,Victor Jr. intake, 770 Holley Avenger vac.sec 400 crank,flat top pistons,tranny shift kit,2500 stall converter. 3.42 ,Hooker Headers,2.5inchpipes with 40 s. Flowmasters,MSD coil,MSD module.
Old Jul 4, 2001 | 07:29 PM
POS Camaro's Avatar
Car: 1986 Camaro Z28
Axle/Gears: 3.73 Posi
I had this happen to me. Anything over approxamately 1/2 throttle caused it to dog out. I had the carb rebuilt and it was missing some brass bushing. This didn't allow the secondaries to act properly (open). Check to see if the secondaries are opening.
Aaron
1985 Camaro Sport Coupe
LG4, 3.08 rear, A4
Bone Stock
1999 Blazer
4x2, 4.3L, 3.42 rears
Decidedly slow
Old Jul 5, 2001 | 12:40 PM
FATZ_86er's Avatar
it could be your choke i would look into a rebuild kit for about $30 and see how that does you
Old Jul 5, 2001 | 09:38 PM
FATZ_86er's Avatar
btw, if you have some blackish smoke pourin out of your exhaust that is a almost a definte choke problem, just for the hell of it put some 94oct in it and maybe that might make a quick fix, you never know best of luck to you
Old Jul 6, 2001 | 11:50 AM
ATOMonkey's Avatar
I don't know a lot about Q-jets, but make sure that any squirters or diaphragms aren't cracked or broken. If they are then you will get poor initial throttle response and no throttle response on a cold engine. Probably a fuel filter though.
'87 Bird 350 .060 over 700R4 + Lots more
pjsparts
Oct 29, 2025 06:39 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
MORREALE5
Sep 13, 2015 09:01 PM
middian
Sep 5, 2015 01:42 AM
86iroczwv
Sep 3, 2015 06:21 PM
