car pops if I floor it from a stop
Car: 1983 Z28
Engine: 6.6L 406
It is the one in my sig with an Edelbrock 750 cfm
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package , dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
future mods:
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Do you mean the engine pops?(not trying to be a smartarse) It just reminded me of two wks ago when I would floor it my engine would backfire(pop) and it turned out to be the timing , apparently the bolt holding down the dist. was loose so the timing moved with the vibration of the engine.
383 86 Camaro Z28
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:234 dur at 050 488/488 lift,2500 stall converter,shift kit,3.42 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.
383 86 Camaro Z28
Could be a couple of different things. Possibly a timing problem. Too far advanced or retarted will produce a pop. It could also be A/F mixture. Too lean or too rich will cause a stutter when you dump it off of idle. I don't know the Edelbrock carb well enough to say how to adjust it, but I had the same problem with my Holley. Turned out to be the accelerator pump cam.
Car: 1983 Z28
Engine: 6.6L 406
sorry I was really tired when I wrote that. I don't know how to time my car and I am having trouble finding a place that will do a high performance car like mine. I have it in a good spot but I know it could be better plus it spits black smoke. My friend brought up a good point that it might not be getting enough air. Because it seems that if I turn the A/F screws in so far that it is about to stall out and it still spits black.
Whew! Oh yeah and I have a harmonic balancer cover that I have no idea how to read it seems so much easier without the cover and just the line on the balancer. Thanks for any help
future mods:
future mods:
Car: 99 Formula
Axle/Gears: 342
Also check to see if your choke needs readjusting.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out and different gears, either 3:73 or 3:42
"There is nothing more addicting than speed"
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
160* Stat
2:73 GEARS
B&M Megashifter
The AF screws have nothing to do with full throttle acceleration that is for idle only. I don't know what this popping sounds like, but if it's spitting black smoke it's probably not detonation, unless it's oil smoke. Check your plugs. If they're black then timing is too retarded, If they're white then timing is too advanced. Also check to make sure your cat isn't plugged up. That will also cause rich condition.
'87 Bird 350 .060 over 700R4 + Lots more
750, accelerating, car, carb, carberature, carbuerator, carburator, cfm, edelbrock, engine, floor, floors, gm, pops, tbi, threw, vibration
