CC q-jet & EGR on L69
Old Jul 1, 2001 | 08:22 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
does the engine rely on the EGR to help correctly regulate air/fuel ratio and combustion temp in the chambers? or can this be closed off with no effect on performance?
in other words: what's better for a mild stock CC q-jet engine,properly functioning EGR or closed-off EGR? I've heard many different stories on this,but nothing to clear this up for me yet,thanks
Old Jul 2, 2001 | 07:38 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Functioning. The ignition curve is tailored to account for the EGR lowering the combustion temp. If the valve isn't functioning, the engine will ping.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Jul 2, 2001 | 11:19 AM
Damon's Avatar
I agree with that. The EGR valve doesn't affect the A/F ratio by much but it is necessary unless you get a chip burned with less part-throttle ignition advance.
Old Jul 3, 2001 | 02:23 PM
Engine: 2.2
thanks fella's!! I'm on way way to the junkyard now to get the right EGR OE #s
Old Jul 8, 2001 | 12:59 AM
Engine: 2.2
it is impossible too find the right egr ( at advance auto anyways) I mounted the cover plate between the egr and intake and it seems to be running fine now. it revs right up to red line and doesn't ping. I should set the timing now,but it does seem to be running fine the way it is.
Old Jul 8, 2001 | 04:04 PM
TransAm383's Avatar
I have a similar dilemma. Are you saying you used a blockoff plate on the EGR flange and then mounted the actual EGR valve over it? I am just trying to get this straight so I don't have to shell out buku dinero for a custom chip.
Old Jul 10, 2001 | 09:16 AM
Dana'86_305's Avatar
i have the performer non-egr intake on mine and haven't noticed any engine pinging. The idle is real crappy right now, but i'm pretty sure that my choke is kinda messed. Actaully i noticed how much crap the EGR system leaves in the intake and i was glad to get rid of it. Is it really that neccessary to get a custom burned chip? This would be the first i've heard of it. BTW i'm still using the c/c carb and dist.
86 Camaro
LG4, Tuned Q-Jet
Edlebrock Performer Intake, Edlebrock Open Element,High Flow Cat,Dynomax Catback,B&M Megashifter, 180* TSAT, 3.42s, 800 Watt System, !EGR
Old Jul 10, 2001 | 04:17 PM
TransAm383's Avatar
The only reason I said anything about a chip was that I read somewhere on here that the computer determines how much ignition timing to use depending on readings from the EGR. I was told that to delete the EGR required a custom chip to add less(?) part throttle timing. If nobody has pinging, thats all I need to hear.
Old Jul 10, 2001 | 05:22 PM
wildman923's Avatar
I'm another C/C Carb and Dist casulty. Main problem I had before the fire was that I couldn't get the car to start with the computer hooked up to the carb. Anyone think a L69 H.O. engine ECM would work better than a LG4 ECM? I have one of each and I'm currently using the LG4 ECM.
Forgot to mention that I'm running all the emissions equip.
BOB
'84 TA
334 SB
"041" heads
+ Dual snorkel and cowl air intake
More to be added once I harvest the money tree.
[This message has been edited by wildman923 (edited July 10, 2001).]
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
