FUEL PUMP....Cmom!
Old Jul 10, 2001 | 08:19 PM
fulo's Avatar
Car: Z-28
Engine: 355
Axle/Gears: Stock
FUEL PUMP....Cmom!
I have a 87 chevy camaro... from my signature you can see what engine I have now. So far I have run the stock mechanical pump. But I have been thinking of changing it. THe problem is that the pump have three ports. The extra one is supposed to be for emissions. I also hear that the my card has and extra electric pump in the tank (previous L69) I have been thinking of puitting and aftermarket pump. The question is :
What do I do with that extra (third) port that goes on the mechanical fuel pump. I am understand that the mechanical pumpt only have an inlet and outlet, and no third port for emissions. Can I just plug it?
1987 Z-28 Camaro
GM ZZ3 Short Block
ZZ3 Cam (208 int, 221 exh, 112 LB)
Trick Flow Twisted Wedge heads (62cc)
Crane roller Rockers (1.6 ratio)
Edelbrock Performer intake
Edelbrock T.E.S Headers (wrapped)
3" American thunder Flowmaster catback
Borg & Wagner retrofit T-56
Mallory Comp 9000 Electronic Unlite Vacuum Advance distributor
Mallory Hyfire V1 (7) Cd electronic ignition
check it out (the engine): www.thirdgen.org/rides/index.tgo?action=view&rideid=3760
Old Jul 11, 2001 | 07:36 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The third port is not for emissions. It is a return line to send excess fuel back to the tank to keep the supply moving so the fuel coming to the pump doesn't have as much of a chance to heat up. Eliminating the return line will likely negate any benefits you would see from an aftermarket pump, especially for daily driving in hot weather.
Although what you are proposing is what CHP did with their project "My Generation Camaro", it isn't wise (they also put on an Edelbrock Performer before cam & headers - go figure).
Exactly what problem are you trying to fix? With the in-tank electric pump and a three-port mechanical, you've got an ideal setup. If the mechanical pump is getting weak (that's what CHP claimed about theirs), just put on a high quality replacement. CHP admitted they used a pump that the owner had sitting around from a previous project, but if that doesn't apply to you, just get a good replacement 3-port.
For what it's worth, for their ZZ4 conversion kit, GM gives you an in-tank pump and a three-port regulator - no mechanical. I don't know if the electric pump in the kit is the same thing your car has, but that is probably even a better way to go.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Jul 11, 2001 | 03:17 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
When I got my crate motor from GM they gave me a part number for a recommended GM mechanical HO fuel pump. It is a 3 port design. I'll try to find the part number at home. Matter of fact I might still have the pump if you want it. Let me look around. I only used it for maybe 2000 miles then I went to a Holley Blue pump.
1985 ASCD Ram Air Trans Am
Readers Ride at https://www.thirdgen.org/rides/index...ew&rideid=1067
-=ICON Motorsports=-
" I get drunk, I race cars and I fondle women. But... I have weekends off and I am my own boss"
Old Jul 11, 2001 | 05:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You could also go with a mechanical high pressure "strip" fuel pump and use a regulator to keep the return line.
Old Jul 11, 2001 | 11:22 PM
michaelc's Avatar
this is to karp when you went to the blue pump what did you do for fuel lines form the tank to the pump did you install a sending unit from an early model? that just had a pickup on it? see my problem is when i did my blue pump i just spliced into the lines that were already coming out of the tank, im not really sure what is in the tank 1987 camaro q-jet
Old Jul 12, 2001 | 04:20 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
I ran all new lines when I switched to Electric, but my car came only with a mechanical pump.
For the record I dumped the Blue pump this year and went back to mechanical(Edelbrock pump). No matter what I tried to do I had nothing but problems getting a steady flow of fuel from the pump. My pressure would also drop in upper RPM's. Changing back to a mechanical pump was like nite and day for my engine.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
