Carb and AC
Old Jul 21, 2001 | 03:13 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Carb and AC
The idle speed drops big time when I turn on the AC. Possible problems?
JamesC
Old Jul 21, 2001 | 07:43 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
What carb are you using? If its the qjet that came with the car it should have a little device that pushes the throttle back to compensate for added ac load. Located drivers side front of carb. If its there it has a plunger thats adjusted by a 1/2in wrench, turn the car/ac on put it in gear with the Ebrake block the tires "safty safty safty" and adjust it to a idle where the car dosent want to die out.
SSC
Old Jul 21, 2001 | 09:10 PM
JamesC's Avatar
It is a Q-jet.
JamesC
Old Jul 22, 2001 | 04:56 PM
sleeper's Avatar
The "little device" is the fast idle solenoid. Check that the single wire running to it gets power when you turn on the A/C. If there's power but the solenoid doesn't push the rod out then the solenoid is broken... replace it. If it moves, but not far enough, adjust as per SSC
Old Jul 22, 2001 | 08:50 PM
JamesC's Avatar
And if no current is reaching the solenoid?
JamesC
Old Jul 22, 2001 | 11:39 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by JamesC:
JamesC
</font>
Then the plunger will not pop out and adjust the idle to compensate for the AC load.
SSC
Old Jul 23, 2001 | 07:35 AM
JamesC's Avatar
SSc,
I understand that, thank you; however, should the solenoid not be getting current, where would I start to effect a repair?
JamesC
Old Jul 23, 2001 | 10:18 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
JamesC
</font>
This indicates a bad wire. If the AC does kick on "clutch cycles/locks" Than splice into the green wire that goes to the compressor its self and run a new wire from there to the solenoid. If this doesent work take the solenoid off and grab a spare wire put the solenoid housing on the ground of the battery and run the power wire to the positive lead and see if the unit is good. If the unit is fryed I think there around 25/35$
Good luck!
SSC
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
