fuel filter question???
Old Aug 7, 2001 | 12:36 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
I went to change my fuel filter in the carb like it says in the haynes maual and pull off the fuel line and there is no filter. so im like ok now what? I bought my car like a year ago and didn't know. This is the thing though I have an electric fuel pump so is it possible that they took out the the fuel filter in the carb and added a in line fuel so where? cause my car seems to bog and I know the filter has to be changed
any ideas?
thanx
86 Z28:
L98 350
aluminum heads
T-5
235/60R15 BFgoodriches
dual 3"flowmaster exhaust
20% tint
hatch wing
2 12"kicker solos
300 watt Sony xplod amp
Sony xplod deck
K&N air filter
http://www.geocities.com/xmikex.rm/mike.html
Old Aug 8, 2001 | 03:04 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Well, in my sertup, the fuel filter is right next to the carb, being an aftermarket setup, I son't have the original parts... If there is a fuel filter in your car you would probably find it somwhere chilling with the other stuff on top of the engine... should be a metal or white plastic cylinder about 2 inches dia. 3 inches long... other than that I would check out fuel lines running to the gas tank, I haven't had a good look at everything under there, but that's where they are on Rx7's... probably not the case for these cars... crazy Japs
1984 Firebird - Daily driver, 305 LG4, T5 - Hurst short shifter, Edelbrock 600 CFM Performer Carb - Edelbrock Pro-Flow air filter, gutted cat, IROC 16x8 Wheels, Goodyear P215/60/R16, AIWA bargain basement (from Sears of course) CD player
Player accessories: fuzzy dice, eight-ball Shift ****
Check out my ride here
Quote from my sister: "It sounds like a boat"
Old Aug 9, 2001 | 09:20 AM
82suped-up-coupe's Avatar
ya jack it up start at the tank and follow the lines forward, it should be about 2 feet forward of the tank on the drivers side, with a bracket holding it to the car, metal cylinder with an arrow on it(make sure to get the new filter in the saw direction)
good luck
Rich
Old Aug 10, 2001 | 09:54 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
i think i remember seeing one under my car like a white cyclender but i think i line runs though it but not out. ill have to go back and check.
thanx
86 Z28:
L98 350
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
