Computer to Avenger 670 Holley
Old Apr 25, 2002 | 06:54 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I was just wondering if there is anything that I must do to the Gas tank or gas Regulator in the tank, since im switching to a Non Computer Carb and HEI distributor. I have install a Holley Mechnical Fuel Pump .
Thanks: DTL504
Old Apr 25, 2002 | 07:50 PM
cdogc350's Avatar
I believe if you run both pumps together you would be pumping 30+ psi. which will destroy your mech. pump. it happened to a friend of mine
Old Apr 25, 2002 | 08:43 PM
DTL504's Avatar
This car did not have fuel injection, so Im thinking that I might not have any problems.
Old Apr 25, 2002 | 11:12 PM
cdogc350's Avatar
Im sorry when it sounded like a fuel inj. to carb swap. you should have no problem with the swap then. the new fuel pump and carb should work fine, i run the same fuel pump and it works great
Old Apr 26, 2002 | 07:52 AM
82camaro's Avatar
Car: 82 camaro SC
If the car came equipped with a computer controlled q-jet, you should have no problems. Both carbs will have about the same fuel requirements. Do you have a pump in the tank? Some thirdgen carbed cars run an electric pump in the tank and a mechanical on the engine from the factory. It works just fine if thats the case.
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
