Taking a Trip to higher elevation...anything to worry about?
Old Aug 2, 2001 | 04:43 PM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
I am going across Donner Pass (about 7000ft at highest point) Saturday morning on my way to hot august nights. My car is tuned for about 1000 feet elevation. Is it going to lean out or richen up? I think if anything it will run a little rich due to the lack of oxygen at that altitude. Will it get so bad I cannot drive it? Any help would be great,
Brit
Black 89 IROC...355, Solid Crower Cam, TFS heads.
12.0 @ 120.3mph with a 1.9 60ft...all motor
Old Aug 2, 2001 | 04:44 PM
BOWTIROC's Avatar
Oh, yeah, I will only be traving at this elevation, I am traveling to reno, which is about 1500ft
Old Aug 2, 2001 | 06:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What induction are you running?
Old Aug 2, 2001 | 08:37 PM
82camaro's Avatar
Car: 82 camaro SC
It will hurt performance, but you will still be able to drive it without any major problems.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Aug 3, 2001 | 12:53 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
It will cause the engine to run richer, but since you are only traveling through it will be no big deal.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage, and just replaced a burnt plug wire
"There is nothing more addicting than speed"
Old Aug 3, 2001 | 11:41 AM
BOWTIROC's Avatar
Sorry, thought that since I posted it on the carb board it would be assumed that it was carbed. But yes, it is a holley DP.
Old Aug 3, 2001 | 03:13 PM
five7kid's Avatar
Reason I asked is a CC carb should adjust with no problems, unless you get into the secondaries.
As said, the Holley will run richer at altitude than it did at home and you'll lose some power. Shouldn't require any changes for the traverse.
Old Aug 6, 2001 | 12:02 PM
BOWTIROC's Avatar
Thanks for your help guys. It did just fine. I had 2 other people in it and all our luggage. With the altitude, boy did it feel like a pig!
Old Aug 7, 2001 | 04:55 PM
five7kid's Avatar
Some of us live there. We've developed an "altitude attitude".
Old Aug 7, 2001 | 05:43 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
ttt
1986 Camaro Sports Coupe
T-tops, power hatch, rear defrost, third brake light
LG4 305 V8, Hooker Shorty headers, 3" pipe into Walker Quiet Flow dual exhaust
Edelbrock Performer intake, "Damonized" Q-Jet 4bbl, K&N filter
Crane ignition kit, TH700R4 transmission and Derale cooler
Air conditioning, pw, pl, pb, ps, tilt wheel
Kenwood cassette, Pioneer 6x4 component front speakers
Rockford Fosgate 6x9 Punch rear speakers
Z-28 front and rear sway bars, Aluminum slots and Goodyear 225x60R15 Eagle HP tires
243 horsepower and 326 fp torque
_ _ ______________ _ _
Yea verily, and he smote the smog demons from the engine, even from the air pump to the converter ...
Todd 1:1
Old Aug 11, 2001 | 03:09 AM
downwithET's Avatar
you get character points deducted for asking
85 TTTA
88 Supra turbo
86 626 turbo
race it or sell it
92GTA
Apr 9, 2016 07:39 AM
Brother Al
Oct 14, 2015 06:39 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
