fuel pump question
Old Apr 25, 2002 | 09:15 PM
trans_am_racing's Avatar
Car: 2000 firehawk
Engine: ls1
Transmission: 6 speed
Axle/Gears: 3.42 auburn
fuel pump question
last week i swapped my motor and trans out of my 87 ta , it was 305 cc q-jet, the car that i put it into was an 89 v-6 mfpi, i hooked everything up and went to crank on it and it started to gush gas out of the top of my car so i un-hooked the fuel pump in the tank and she runs fine for the most part but now my fuel gauge dosent work, if i hook the pink wire that controls the gauge it works, but with having the one wire, will it run the pump in the tank at all......?
Old Apr 25, 2002 | 09:18 PM
Jester's Avatar
You can't run a carbed motor on a MPFI fuelpump. You'll need to either change the pump, or put on a 3 port bypass-style regulator.
Old Apr 26, 2002 | 04:12 PM
Car: 2000 firehawk
Engine: ls1
3 port by pass
where would i be able to get a 3 port by pass at and how much do they usually go for?
Old Apr 26, 2002 | 06:44 PM
Jester's Avatar
You can get one from Summit or Jegs, and they run about $80.
Better off replacing the pump.
Old Apr 27, 2002 | 01:08 AM
2ponchos's Avatar
TA_racing u can get the regulator its a mallory part #4309 its 74 dollars out of summit or jegs hope this helps
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
