Jet size recommendation
Old Apr 27, 2002 | 05:59 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
engine and carb discription is in sig. right now there is 67 in the primaries and 77 in the secondaries what should i put in there for a basic start in tuning. i think 77 is too big for my application am i wrong?
thanks
brady
Old Apr 28, 2002 | 03:28 AM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
From what I was just reading, with the dual plane intake, and the DP, a 77 in the rear might not be a bad thing. I would put the car together and run it. The jets are easy to change. I can do mine on my other car in about 20 min. If you drop the size to much it will hurt you alot. I tried it with my car and I was getting to much air and the car ran like sh*t. It should be fine, after all it is only a 600. Just make sure it can breath.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
