Fuel Pump replacement
Old Aug 21, 2001 | 12:54 AM
drt-rcr's Avatar
I am going to replace the fuel pump in my bird in the next couple days. Is there any pitfalls I need to be aware of? It's in a 91 V-6 3.1 Firebird.
Thanks,,, Matt
Old Aug 21, 2001 | 09:04 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
The hardest part is getting the tank out to get at the pump,after that it is all straight forward.I did my pump on my 86 TPI T/A in about 3 hours taking my time.Good Luck
Old Aug 22, 2001 | 03:29 AM
83CrossfireBomb's Avatar
did you have to almost drop the rear out the car to get the gas tank out? or is there a way around that?
former 305 crossfire fuel injection
350 cubes
hooker headers
750 vac secondary
700r4 with shift kit
Old Aug 22, 2001 | 07:50 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I had to undo the rear brake hose,shocks and panhard bar and let the read drop as far as it could to get the tank out.I also had to remove the cat back to gain room to get the tank out.After that it was a breeze,just a lot of bull to get it out but really not that hard.
John
Old Aug 22, 2001 | 10:08 AM
drt-rcr's Avatar
It sounds like a real PITA. I'm getting ready to start on it right now. I hope I can get it done in three hours like you did. I will be able to drive it to work today. I haven't driven it for several months due to too many other projects ahead of it.
Thanks,,, Matt
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
