Tech article about help with Q-Jet
has anybody tried this with their q-jet? is the difference noticable??? thanks for your help guys!
'87 Sports Coupe, 305 4 bbl, flowmaster exhaust. Other then that just stock (i know its not much but i just got a new job woohoo)
Transmission: 4L80E/4L80E
With the exception of the part about getting the AV to open fully (I've never run across a q-jet that needed that mod), everything in there is standard q-jet tuning stuff.
Yes, it makes a noticable difference.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet (Holley 3310 on the way), GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Hawk- Try the can off an Edlebrock #1910 QJet replacement carb. You'll have to call Edlebrock and figure out how to get one (it's not a tuning part, it's a service replacement part). It has the faster opening rate you are looking for and will bolt right onto the side of any Computer Controlled QJet.
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I've been told by Edelbrock they don't sell it separately. Maybe if I pretend to have one that broke, I could get them to sell me one.
