choke light stays on?
Old Aug 31, 2001 | 07:14 PM
zee28's Avatar
Car: 86 iroc
I took my car to get it inspected today.As always I had to put the stock air cleaner,smog belt on it.I get the car back and now the choke light is on.Could they have done something,ya think.Something else is the alternator died on the way home.I have never had a problem with either.The carb. is about 6 months old(reman) and has ru perfect since I got it.The car still runs good and when I unplug the choke the light goes out.The choke seems to be working right,it was hot though so it was full open.I did go back and ask the guy if they messed with anything and of course he said no.Its weird they both happen at the same time,but it is my luck.its a 305 lg4.c/c carb.thanks
~mike~86 IROC-Z
Old Aug 31, 2001 | 07:34 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Due to a bit of overly elegant engineering on the part of some idiot that doesn't understand the purpose of warning lights (I guess he thought they were for interior decoration or something ) the "Choke" light is also the "Alternator" light! Think about it for a minute.... you've got a choke in one hand, and alternator in the other... why, just look how alike they are! I am like so sure that any consumer would be able to figure out that when the "Choke" light comes on, that means they're supposed to replace the alternator!!!
And I'll bet the idiot in question probably got a raise for coming up with that.
Anyway, fix the alternator, the Choke light will stop coming on.
ICON Motorsports
[This message has been edited by RB83L69 (edited August 31, 2001).]
Old Aug 31, 2001 | 07:49 PM
zee28's Avatar
Car: 86 iroc
are you kidin me?dont I have an alt. light too?anyway I will change the alt tomm.and find out.
~mike~86 IROC-Z
Old Aug 31, 2001 | 07:55 PM
zee28's Avatar
Car: 86 iroc
guess I dont if I have a gauge,huh
~mike~86 IROC-Z
Old Sep 1, 2001 | 08:50 PM
EDDIETA_ZZ3's Avatar
Car: Trans Am
Engine: ZZ3 HO
Transmission: 700R-4
Yep, the choke can also be a warning for the alternator. Also, on some years, it could also mean the oil pressuse switch is not connected. My 87 T/A does this, or check if you have a fuse blown for the instrument panel.
Old Sep 1, 2001 | 11:24 PM
zee28's Avatar
Car: 86 iroc
yep,it was the alt. making it come on.thanks alot
~mike~86 IROC-Z
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
