What are symptoms of too much fuel psi?
Old Sep 24, 2001 | 12:54 PM
Biochem's Avatar
Car: 2002 SOM z28
I am running about 7psi at idle witha Carter mech pump on my Holley 750vac. As some of you may well know, my A/F guage reads normal until a few seconds later when it creeps up into the rich range. I haven't checked if it does this when I just start it up and idle only...
I've checked the float level, the needle/seat look OK, and I've cleaned out all the passages multiple times. No adjustments I do seem to make a damn bit of difference on this... Could a surge in fuel psi (perhaps due to a restriction through the 1/8" pipe fittings in the inline fuel filter) bump the psi up so high that it floods the primary bowl?
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Sep 24, 2001 | 01:09 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
It is a possibilty,lower your fuel pressure to 6 psi and see how it acts.My Demon ran pig rich at 7 psi,lowered it to 6 psi and it runs great.Are you checking the pressure with a gauge?I ask this cause i had a Carter mechanical pump on my car that was supposed to be a "7 psi" but was more like 9-12 when i finally checked it with a gauge.I have had stock replacement pumps that put out more than 7 psi 99% of the time.I now run electric with my new fuel system.
1982 Z28:355,4 Speed,Lots of bolt ons
Old Sep 24, 2001 | 09:35 PM
Jester's Avatar
Flooding/running too rich.
Turn it down and see. I've run as low as 3 psi with no problems whatsoever. Not really a reason to set it higher at this point.
Old Sep 25, 2001 | 02:04 PM
Biochem's Avatar
Car: 2002 SOM z28
Well, I've checked it with two separate gauges and they both read about 6 1/2-7psi at idle... I don't know what they'd be at when I drive around.
9192camaro
16
Feb 3, 2019 12:21 AM
jklein337
Sep 19, 2018 06:23 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Kaweh
Aug 9, 2015 02:54 PM
