Ignition system for carb setup switching from TBI
Old Oct 29, 2001 | 03:33 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
I read the tech article, and it doesn't help me much here. I was wondering if anyone could recommend a distributor for me. I'm switching from TBI to carb adn want to keep the tach. Will I need an aftermarket ignition module (MSD, etc?). I'm assuming the ACCEL coil I have won't work. Thanks.
Assume I'm stupid and tell me what I need as far as ignition goes when switching over.
Old Oct 29, 2001 | 05:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You should assume we're stupid and tell us what kind of Accel coil you have.
Any vacuum/mechanical advance distributor would work. That includes factory HEI, aftermarket HEI, or any version of an electronic trigger aftermarket such as MSD, Accel, Mallory, etc.
Any factory HEI should be assumed to need upgrades to the coil and module. Adjustable vacuum advance is a nice touch, spring/weight kits are available to taylor the advance curve.
Your tach should work with any of these by hooking your current tach wire up to the negative terminal of the coil (or the tach terminal, if provided).
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. 2-1/2" cat-back, ZZ4 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (ported World 305 heads, Crane PowerMax cam, Hooker 2055 headers, 3" Catco cat & 3" catback w/Flowmaster, restalled TC, Spohn SFCs).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
[This message has been edited by five7kid (edited October 29, 2001).]
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
pimp2303
Jul 27, 2017 02:03 PM
Fast355
Dec 2, 2016 06:33 PM
