How do I adjust my Idle Air Bleed???
Old Nov 7, 2001 | 12:16 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
I need help with this here. I have an 83 T/A with a stock 74,000 mile LG4. My car has a terribly rough idle. Above idle, it runs fine. I have no vacuum leaks, and they are all routed correctly. I was told to adjust the IAB. Where is it and how do you do it. I heard it is with a dwell meter...correct? Please tell me as I need my car for daily transportation. Thanks in advance.
1983 T-top Trans Am. All stock (for now) LG4/auto/3.73 posi. 70,000 original miles. SLOWLY going through a Knight Rider conversion. (it will be done one of these years)
Bset of 15.79@86mph 2.16 60ft
1963 Dodge Dart drag car. 360/904/4.88
Best of 10.94@120.44mph
Old Nov 7, 2001 | 09:48 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
The idle air bleed is in between the primaries, on the large "tower". You adjust it with a big flathead screwdriver. You're supposed to adjust it using a procedure detailed in the Helms manual that I can't remember off the top of my head.
Yours may have a cap over it. You'll have to remove it if it does. But--if the cap is there, chances are you don't need to mess with it.
specialized
Jun 18, 2022 09:26 AM
backtothe80s
Sep 5, 2015 12:39 AM
86IROC112
Aug 21, 2015 07:20 PM
perZ
Aug 15, 2015 01:17 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
