Trouble removing the plug for the TPS adjustment
Old Nov 9, 2001 | 10:27 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Hey guys, I gotta adjust my TPS on my extra Qjet... the problem is, it had that damn plug in there.
First thing I did was drill a small pilot hole and try and break it loose with a screw. No dice, the screw just stripped the threads. So next I tried a screw extractor... no dice there, I might as well have been using a drill bit. Which is what I did next, drill the plug out. The problem is the damn drill bit is pointy, and hits the adjustment screw and stops. Unfortunately, it left a "ring" of plug material around the screw, enough to prevent me from getting the adjustment tool on. I've tried tweezers, screw drivers, you name it... I can't get enough of the metal removed to turn the screw.
Help???
"Beware he who would deny you access to information, for in his heart, he dreams himself your master"
'84 Black Camaro Sport Coupe ZZ4 350 M6 -- '84 Olds Cutlass Supreme 231 A3
'91 Medium Blue Metallic Z28 400 A4 -- '99 Navy Blue Metallic Firehawk #120 346 M6
Old Nov 10, 2001 | 10:43 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
For lack of a better idea, may as well remove the air horn and try to get the screw out from below, then you can drill the rest of the plug material out.
Old Nov 13, 2001 | 08:16 AM
99Hawk120's Avatar
I have the air horn off. I can't figure out how to turn the screw from under there since it is in a really awkward spot. And that's after getting the "claw" out of the way that the screw actually pushes on.
specialized
Jun 18, 2022 09:26 AM
perZ
Aug 15, 2015 01:17 PM
camaroken83
Aug 10, 2015 11:35 AM
3rdgenparts
Aug 8, 2015 07:09 PM
