tbi fuel pump on carb
Old May 9, 2002 | 11:24 PM
Derek91z28's Avatar
I made the switch from tbi to carb a while back, but since then the car will die one time after i drive about five minutes. I'll turn the key off for thirty seconds or so then the pump will prime again and the car fires right up. I've read on here that there's a wire to hook up to the fuel pump between the back seats or something along those lines. I know my pump isn't going out because it only does this once in the morning on my way to class. how do i fix it or should i just invest in a holley red and put a regular pick up in the tank.
Old May 10, 2002 | 10:34 AM
TBI305Camaro's Avatar
i think you need to bypass the relay so its always running when the key is on i think thats what the wire is your talking about...how you like the swap??
Old May 11, 2002 | 04:22 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
how do you bypass the relay?
Old May 12, 2002 | 12:51 AM
Derek91z28's Avatar
i love the swap i gained a sh!tload of power from it. the only draw back is this damn thing keeps dying on me in the mornings and im tired of it. plese let me know which wire it is i need to hook up to a constant.
Old May 12, 2002 | 01:03 AM
what mods have you done?
i am in the middle of the swap right now getting the carb intake torqued down.
how do you bypass the fuel relay so that it is on when the key is on?
Old May 12, 2002 | 01:08 AM
Derek91z28's Avatar
i have no idea thats my question........ i have a 350 vortec heads and intake 650 holley DP, headers exhaust, gears and a "built" 700 r4.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
