secondary/stutter question
Old Nov 18, 2001 | 04:53 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
hi guys i have a 305 with the stock q jet and a crane powermax 2032 camshaft, when i use the 4bbl in 1st gear (5 speed) the thing pulls like a bat out of hell, but when i hit 2nd it pulls a little then starts stuttering, also i notice it stutters in any gear holding a steady rpm, what would cause this? the camshaft is designed for 2000-5500 rpms, and i think 3.45 or higher gears, i have 3.23's could the rear gears be causing this? i'm upgrading to 3.73's soon.
Old Nov 18, 2001 | 11:42 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
I doubt if it is the gears. Check out the QJet article on the Tech Articles and follow the steps. Works very well.
My bogging problem was mostly corrected by putting a 50,000 volt coil in the ignition.
Old Nov 18, 2001 | 11:44 PM
Engine: 305-4v
Also check your fuel pump and filter. That almost sounds like their classic signs.
Between the three things I mentioned, I'll bet you nail it down
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
