* which rods and hangers should I use? *
Old May 10, 2002 | 10:11 PM
85_ZED28's Avatar
Car: '85 Z28
well, as the subject says: which rods and hangers should I use??
car in sig.
I've seen people using CK, DR rods and B, and other hangers ,so what is the difference between them, and how do I know which ones to get?
Thanks for any help! :lala:
P.S.
(I want to try and change them tomarrow, since it's the only time I have off for a while, so any tips on doing the job would also be greatly appreciated!)
Old May 10, 2002 | 10:54 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Go to the Tech Articles and look up the one on tuning a QJet. It is very comprehensive.
Old May 12, 2002 | 01:51 PM
85_ZED28's Avatar
Car: '85 Z28
I checked the archives before making this post, they don't tell wich rods to use for each application. Just wondering if anyone has any info on which ones to use
Old May 14, 2002 | 09:08 AM
85_ZED28's Avatar
Car: '85 Z28
anything??
Old May 14, 2002 | 04:34 PM
Engine: 305-4v
Originally posted by 85_ZED28
anything??
I already gave you the best answer. I did not suggest the archives ...
Old May 15, 2002 | 08:25 AM
MD83Z's Avatar
I have the CK and B hangger cause thats what Summit sells. The DR rods seem to be the most popular(around here), so I'm guessing that it feeds more fuel a little sooner as the rod raises up. You should also adjust the spring tension on the secondary AV flap. My vette has the non-computer carb and uses the same rods and hanggers. Right now the AV flap is too loose so I'm getting bog when I get on it.
Old May 18, 2002 | 05:09 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
I'm using a set of DR rods and an "N" hanger on my SC; only reason for using the "N", is 'cuz I had it on hand and haven't found anything better yet...
Pete
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
