Holley
Holley
Hilo,
I want to tune my Holley 600 and want to know the easiest way to do it. Any information would be great. It's on a 350 SBC with an accel Dist. converted to mechanical (weights and spring) advance.
TIA.
Loki
TIA.
Loki
my signature didn't work... why not?
1986 T/A. 305 replaced with 350, bored .030, Edelbrock Performer intake, Holley 600 carb, A/C delete, computer delete, smog delete, A.I.R. delete, Accel distributor converted from vacuum to mechanical, stock heads, cam is the best I cold run with the computer (need to change it), flowmaster muffler, and a TH350 tranny with B&M shift kit
Transmission: 4L80E/4L80E
What do you do with this car? If you drive it on the street (at least more than just getting it to the track), you would really benefit from a vacuum advance. Having or not having that will affect carb tuning.
For starters, I'd suggest you find a book that describes the theory on how the Holley works, which will also get you on the road to tuning it. As it is, we haven't got a clue if you understand floats, jets, power valves, accelerator pumps, primary vs. secondary circuits, idle circuits, etc. I got such a book from Summit when I got the carb. Not the best, perhaps, but it got me started, and it includes tuning tips.
Also, stock what heads? Cams affect tuning, as does exhaust (headers? cat back? size?).
Bottom line is tuning is a matter of trial and test. No one can tell you remotely exactly what you have to do to get the car running perfectly.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
RaverRacerX
Mar 17, 2026 01:49 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
