Holley 4160 question........
My question is, on the left side (driver side)of my carb. It looks like there is
a small L shaped rod that slides on
a half circle that is conected to the secondarys. Sorry if I confuse anyone
trying to discribe it best I can. Anyway
it looks like the rod blocks the secondarys
from opening more than they should as the primarys open. So if I bent this rod would
it let the secondary open wider at a given
rpm. Hope some one knows what im talking bout..Thanks for any input.
86 T/A L98 with T-5(orig an LG4)
Hooker headers
Performer RPM intake
holley 750cfm carb
cast iron 76cc heads with
2.02-1.60 valves
B&M ripper
Richmond 4.10's
Flowmaster
9.43@74mph 1/8 mile.
Hooker headers
holley 750cfm carb
2.02-1.60 valves
B&M ripper
Richmond 4.10's
Flowmaster
Car: 82 camaro SC
Secondary lockout. It blocks the secondaries from opening at part throttle. Why would you want to change that? Without it the secondaries could potentially open without the throttle open very far. You won't gain any performance.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
82camaro
If I'm thinking of the right thing..it also closes the secondaries when you let off. I'd leave it alone
If you think you need more cfm from the secondaries opening more...get a bigger carb.
[This message has been edited by Jester (edited December 08, 2001).]
If you think you need more cfm from the secondaries opening more...get a bigger carb.[This message has been edited by Jester (edited December 08, 2001).]
Transmission: 4L80E/4L80E
You get them to open farther by putting a weaker secondary spring in. You use the weakest spring that will not cause a bog when you nail it.
A vacuum secondary carb opens based on demand. When tuned properly, it will not open until the engine needs it.
It's hard to say based on what you say in your sig, but I would guess a 750 is more than your engine can use, so the secondaries won't open up quite all the way. If you look at the chart that came with the carb, it would take in the neighborhood of 6500 rpms to open it fully.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Car: 82 camaro SC
This is a common complaint with a vacuum secondary carb. Actually you shouldn't feel the secondaries open up. If you do feel them, you probably have too light of a spring. They only open up as far as the engine needs. Get a bigger engine and they will open up farther. Like 57 said, install a ligher spring if you want them to open farther.
82camaro
82camaro
RaverRacerX
Mar 17, 2026 01:49 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
