Car stalls
Old Nov 27, 2001 | 01:42 PM
Sandman's Avatar
Car stalls
I have a 87 Trans Am with the LG4 engine. The car starts fine. When it is in park it runs fine but when you put it in drive or reverse it stalls. I was told that the carb might need rebuilt, I got it rebuilt and it ran fine for about two or three weeks but when I started it up the other day and put it in gear it stalled. Please help. Thanks Ross
Old Nov 27, 2001 | 02:06 PM
Jester's Avatar
What is the idle speed in park and in drive?
Old Nov 29, 2001 | 02:57 PM
Sandman's Avatar
The idle runs around 1 or so in park, when it is in drive the idle goes up and down from around 1-.25 and then it stalls. normally the drive idle is around .5 or .75 when I had it rebuilt.
Old Nov 29, 2001 | 03:21 PM
VampireHunterC's Avatar
You could try increasing the idle speed slightly.
Old Nov 30, 2001 | 07:27 AM
82camaro's Avatar
Car: 82 camaro SC
Lean Idle can do that. Try making the idle a bit richer.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 30, 2001 | 05:20 PM
86-red_dawg's Avatar
how do you go about doing that? i just rebuilt my carb and it stumbles a bit when it's cold and first cranked, and don't know which screw to turn
Old Dec 9, 2001 | 03:11 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
If memory serves me right, someone correct me if I am wrong, the idle screw is on the drivers side of the carb. It should be the only other screw that adjusts other than rich or lean. It is best to adjust w/ two people. One to watch the tach and one to adjust.
1989 Camaro RS, 355 engine, 4 bolt block, 11.5:1 compression, 305 heads--ported, polished, milled, 3-angle valve job, 2.02 intake and 1.60 exhaust valves, Edelbrock rpm valve springs, 1.5 rockers--, Keith Black pistons, solid lifter cam, Edelbrock RPM intake, 750 cfm Holley, Holley Red electric fuel pump, MSD distributor, Turbo 350 w/B&M Shift kit, 3.73 Richmond Gears, Hooker headers, Flowmaster exhaust
My Pontiac's (my babies)
1972 Pontiac LeMans, 2 Door, red with tan top, 350 V-8, Edelbrock Perf. Intake, Rochester Carb, Turbo 350 trans with B&M shift kit, Dual Exhaust
New Addition (Don't tell my girlfriend!! [she found out...whoops]) 1968 Pontiac GTO, Rust free body, White with Black Interior, Original 4-Speed Car, 400 V-8 engine, Hideaway Headlights, Positraction Rearend
http://www.fbody.com/members/Camrs89/
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
killer777
Aug 8, 2015 02:47 PM
