Cold air intake
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
Cold air intake
Is there any good Cold air kits for carburated cars? My car is L69 car but it has K&N but not the originall setup.
There is nothing on our junk yards (I am from Iceland, mostly japanese junk over here and certanly no L69 intakes).
Thanks in advange,
Nonni
Thanks in advange,
Nonni
Go to your local hardware store, and browse the ailes. There must be 100 ways to make a CAI from the stuff in there. Use dryer ducting, PVC, whatever you can find. Be original.it's more fun that way
But you will need some sort of snorkel intake..those can be a little difficult to make from scratch. I havn't a clue where to tell you to look over there.
There is www.ramairbox.com ,but those cost an arm and a leg.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
[This message has been edited by Jester (edited December 10, 2001).]
But you will need some sort of snorkel intake..those can be a little difficult to make from scratch. I havn't a clue where to tell you to look over there. There is www.ramairbox.com ,but those cost an arm and a leg.
JSP Motorsports
ICON Motorsports
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
If you have an 82-84 Z28 (or the hood from one) I'm designing a ram/cold air intake that uses the stock hood scoops (even the blocked off ones in '84) that sucks air in through the scoops and comes down into the air cleaner. The hydrolocking problem has been thought of, I 'm going to use PVC pipe that has a flexable elbow between two equel length pieces. When the hood is popped the pieces are extended straight and when it's closed they form a "V" shape, there will be a hose that routes water from the tip of the "V" down under the car where it belongs. I hope it works and if it does I'll be sure to post a tech article and let everyone here know.
Don't hold your breath,
Matt
POWER AT THE COST OF BODY WORK...
1984 Camaro Z28 - Black w/ Grey int.
-GMPP 350 (72cc heads, 8.5:1 CR, & .390 intake/.410 exhaust cam) with Edelbrock 600 Carb, Edelbrock Preformer RPM intake, AC Delco plugs, 8mm AC Delco wires, 14" Accel filter, Edelbrock Chrome valve covers, breather, and Air cleaner.
- Profesionally Built Turbo-350 with 2500 RPM Stall converter, Hurst shifter, & one wicked shift kit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
-Comming Soon:
3.73's, MAC Cat-Back, hollowed cat., B&M Megashifter, & Paint: Navy Blue Metallic w/ Silver strips
Pics & more at: http://members.fbody.com/flashz28/
Matt
-Comming Soon:
how bout take the thingies out and use an open element? thats what i do, pulls a little harder once ya get goin i think, i dont know really, had to take it off for clearance purposes...looks pretty cool anyway, should look cooler once i get my racin stripes on that will match my air cleaner
Car: 86 T/A
Engine: ZZ383
I have an open element right now, it looks cool but it can be really hot under the hood (headers) and I want cold air.
My Holley gets rather hot but I dont have room for spacer and the open element. If I can move the filter I have room for the spacer.
Nonni
P.s. it can be hot in Iceland
Nonni
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
kyle5647
Aug 15, 2015 11:56 PM
