idle off
Old Dec 10, 2001 | 05:26 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
idle off
a couple of days ago, i started my car and it began to idle high, between 1100-1250 rpm's depending on how warm the engine was(i didnt set the choke). i thought perhaps the secondaries were stuck, so i bought some carb cleaner and gave it a good spray for about 8 minutes while i played with the throttle. the idle went down to normal (750 rpm in park), but the minute i drove it, it came back up to 1250. the choke linkage is about 1 year old so i doubt its that. any ideas??
1986 IROC-Z
305 LG4 w/ TH700-R4
Edelbrock TES headers & Y-pipe
3in Edelbrock cat-back
K&N air filter
Direct wired fan
TransGo shift kit
Old Dec 10, 2001 | 09:39 PM
Rumblin91's Avatar
What kind of carb are you running? Is it an electric choke? If so, make sure it's "plugged" in. Sounds simple, but if it isn't that will cause the throttle to stick
Old Dec 11, 2001 | 06:17 PM
curt86iroc's Avatar
Car: 1990 IROC
im running the stock cc qjet. what do you mean the choke must be plugged in?
1986 IROC-Z
305 LG4 w/ TH700-R4
K&N air filter
Direct wired fan
TransGo shift kit
Old Dec 12, 2001 | 08:58 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Could be a worn out fast idle cam. My E2SE had that problem... first the fast idle became unpredictable (IE would fast idle sometimes when it really wasn't supposed to). Within a month the fast idle quit completely, and I had to manually give the motor gas when it was cold.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
