Need a carb recommendation....
Old Dec 14, 2001 | 11:50 AM
CamaroX84's Avatar
I am buying the Fastburn crate motor (350 ci) and putting in the LT4 HOT cam (430 HP, 430 lb ft. of torque). What carburetor should I throw on it? I'm new on the carb scene, but I was thinking a 750 cfm. What brand do you guys particularly like? I'm looking for one with a lot of custom settings (unless they're all the same I really don't know). Any help would be greatly appreciated. Thanks.
Old Dec 14, 2001 | 12:42 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I am partial to Demon.I like my Speed Demon 750 DP,easy to tune and holds it,unlike the Holleys I have had in the past.
1982 Z28:355,4 Speed,Lots of bolt ons
Old Dec 19, 2001 | 11:11 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
A 750 Holley double pumper would be my choice if it was up to me Holleys are real easy to learn and tune.
Old Dec 20, 2001 | 02:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If I had to do it over again, I would get the Demon, no doubt about it.
The Demon tunes like a Holley, but is less likely to need it out of the box. Higher quality castings & finish, each unit flow tested wet before boxing, more power vs. same size/type Holley - all good reasons to spend the few extra bucks.
FWIW, the Demons are flow-rated "wet", so their numbers are conservative (i.e., a wet-rated 750 will flow more and make more power than the typically dry-rated other brands). Also see Jester's post below about picking a carb size.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
