emissions yuck!!!!
Old May 31, 2002 | 08:52 AM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
Axle/Gears: stock/3.42
emissions yuck!!!!
i just recently installed an aluminum intake and edelbrock carb. I had to go withe the intake with an egr provision due to emmisions but when i try to install the egr valve with the carb there is no room for the egr valve, it hits on the carb... anybody with any suggestions????? either an adapter or a smaller diaghram egr valve part # thanx
Old May 31, 2002 | 10:48 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm a little surprised you need an EGR but don't have to have the CC carb.
I don't have an answer for you, although a carb spacer may help. Alternative would be using a q-jet - we know it will clear.
Old May 31, 2002 | 01:01 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
i havent had them look for anything except egr valve, air pump and converter that s all they have ever looked for. most of the people who run the tests couldnt tell you the difference between a cc carb an a non cc carb:lala:
Old Jun 1, 2002 | 12:02 AM
jeffs82z28's Avatar
Edelbrock website says that you need to use P/N 1476 egr spacer.
Old Jun 1, 2002 | 12:04 AM
jeffs82z28's Avatar
I just re-read your post. I would assume that the spacer would work on the holley manifold. But you know what happens when you assume some thing.
Old Jun 1, 2002 | 08:53 AM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
thanks for the part # ill have to investigate a little
Hotrodboba400
Dec 10, 2019 07:07 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
TBRays98
Sep 6, 2015 05:05 PM
