secondaries wont open
Old Jun 30, 2002 | 10:26 PM
JunkHead84's Avatar
on my edelbrock 600 the secondaries wont open up. i tried to ghetto rig it with a spring on the linkage and it worked it opened them up but it wouldnt retracked that good leaving me with a high idle. im pretty sure they are not vaccuum secondaries and im pretty sure they use to open back in the day. can anybody tell me whats going on with my secondaries. thanks
Old Jul 1, 2002 | 04:06 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
What exactly is not opening? the secondary throttle blades
or the air valve?
Old Jul 1, 2002 | 02:10 PM
JunkHead84's Avatar
the throttle blades
Old Jul 1, 2002 | 03:36 PM
F-BIRD'88's Avatar
You probabily got this carb used at a real good price right?
Sounds like somehow the linkage got messed with, removed
or bent.
Maybe you could find someone who also has this carb and look
see how the linkage works on their's and see what's messed
up on your's. Sorry I couldn't be of more help...
Old Jul 1, 2002 | 10:50 PM
JunkHead84's Avatar
the carb came with the motor it was only 2 weeks old like 2 years ago. anyways i fixed it, i took off the pin that connects the 2 linkages and i squeezed it alittle more together with pliers to create more tention and it worked. it hit me by suprise it almost sucked my face in. thanx anyways
Old Jul 2, 2002 | 01:52 PM
MouseCamaro305's Avatar
someone correct me if lm wrong, or feel free to add additional information, but normally with vacuum secondaries, (which lm not sure weather or not you have) when the cars not under load and you give it full throttle the secondaries dont open. unless you've driven around and the car at wot feels extremely slow, your secondaries are probably opening under load. you should find out weather or not its vaccuum or not, and reply back.
Pac J
May 17, 2020 10:44 AM
racereese
Oct 10, 2015 09:39 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
RedLeader289
Sep 23, 2015 06:50 AM
gta892000
Sep 16, 2015 12:37 AM
