Where can I buy a PRIMARY holley metering block? not the secondary
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
My primary metering block on this used holley I rebuilt is total garbage.....where can I buy a new one??
I'm not 1000% sure, but I do believe that Holley sells them as replacment parts. Should be available through any Holley dealer. Any reasonably well stocked speed or carb rebuild shop ahould have extra laying around too.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Rob one out of a 600cfm #1850.
get a numbered drill bit set and find the size that just fits in the
power valve channel restriction on the 750 metering block.
Drill the 600 metering block power valve channel restriction to be the same. switch jets ,,There ya go.
C409
Sep 23, 2015 04:30 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
