Carburetor Question!?!?!
Old Aug 22, 2002 | 06:31 PM
stevver84Z's Avatar
Car: 1990 Iroc Hardtop
My car, has a lot of trouble between 500-1300 RPM. It feels as if its stumbling or missing. It has a rebuilt carb, new plugs, wires... i need some advise on how to tune the carb if it is the problem.... maybe timing needs adjusted??
Old Aug 23, 2002 | 09:37 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
ALWAYS have the ignition up to snuff before you start messing with the carb. Try 6 degrees base timing (assuming plugs/wires/cap/rotor/coil/etc. are all in good shape). See how it runs then.
What air cleaner are you running? If open element, that's a common problem with that setup. The snorkel air cleaners have the thermovac system to keep the inlet air at a consistent temperature, and this little stumble is common it it isn't there or isn't working right.
After that, you're looking at adjustments. Let us know if it still needs help.
Old Aug 23, 2002 | 09:27 PM
stevver84Z's Avatar
i do have open element air cleaner, however i just put hedders on and they didnt come with the thermovac hookup, i will try adjusting timing, see if that helps, thanks
Old Aug 24, 2002 | 08:13 PM
demonkey36's Avatar
Car: 1991 Camaro RS
Engine: Was 305 LO3 TBI, now carbed 355
so open elements are a no-no with carbs?
Old Aug 25, 2002 | 12:23 AM
EvilCartman's Avatar
Car: '82 Z28
I'm running an open element and haven't had a problem with stumbling.
colton_carlson
Mar 8, 2019 12:21 PM
masonta
Aug 31, 2015 10:14 PM
beachrodder
Aug 25, 2015 08:05 AM
redmaroz
Aug 16, 2015 11:40 PM
Jake_92RS
Aug 11, 2015 10:39 AM
