Backfiring on acceleration
Old Sep 15, 2002 | 01:10 PM
jemery's Avatar
Hello, I have a Quadrajet on an AMC 401, and when I stomp on the gas the carb backfires, then it runs fine. Also the 4 barrel doesn't open. Is there an easy solution? I don't know a whole lot about carbs. I also have another q-jet that I could use, but it has connectors for some sort of wires. Do you need these?
Thanks for your help in advance.
Jeff
Old Sep 16, 2002 | 11:08 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Check your timing. I just fixed that problem on my Olds and it was 5* retarded.
When you say the secondaries aren't opening, are you referring to the actual throttle blades or the air valve? Also, Qjets have a secondary lockout attached to the choke mechanism (unless you've removed it)--are you checking them with the motor hot or cold?
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
racereese
Oct 3, 2015 03:46 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Racerx974
Sep 19, 2015 10:16 AM
