carburetor maintenance
Old Sep 24, 2002 | 08:04 AM
camaro84boy's Avatar
Just wondering what one can do to keep a carburetor in good working condition. What services can and should be performed and when?
Old Sep 24, 2002 | 12:19 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I usually spray my Demon down around once a month with carb cleaner spray and wipe it off as best I can,making sure to get a real good spray of the idle and high speed air bleeds.Check for any leaks or anything out of the ordinary.The only other thing I may do from time to time (every few months) is run a can of Seafoam thru the fuel system (pour into the gas tank) and that is about it for me.Change or clean fuel filters as necessary.As long as you keep up with a regular maintenance plan,carbs are usually good to go.
djmarch
May 8, 2016 11:32 AM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
