Base timing for a 83 camaro 305
Old Sep 25, 2002 | 11:48 AM
RallySport92RS's Avatar
My friend just installed a 83, 305 engine out of a camaro into his 86 GMC Jimmy. He has a high performance cam, intake and exhaust with a 4bbl 600cfm carb. He is wondering what his timing should be set at because right now it is backfiring.
Old Sep 25, 2002 | 09:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Factory settings with the CC setup were between 0 and 6 degrees.
If he's using a non-CC vacuum/mechanical advance distributor, it's typically 8-12 degrees at idle with the vacuum advance disconnected. Total mechanical with vacuum disconnected should be around 36 degrees.
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
